2015-06-25 03:52 AM
Do ST have any data regarding Program/Data Flash write cycles and/or wear levelling for the SPC560B device(s)? I'd like to know if we have the option of using the Data Flash for built-in test logging on our SPC560B64.
2015-06-29 07:54 AM
Hello Kevin ,
SPC560B has a NOR FLashThe Erase Cycles Allowed should be between 10000 and 100000. Best Regards Erwan2015-06-29 07:54 AM
Hello Kevin ,
SPC560B has a NOR FLashThe Erase Cycles Allowed should be between 10000 and 100000. Best Regards Erwan2015-06-30 07:29 AM
Thankyou.
Kevin
