Flash memory write cycles
Options
‎2015-06-25 3:52 AM
Posted on June 25, 2015 at 12:52
Do ST have any data regarding Program/Data Flash write cycles and/or wear levelling for the SPC560B device(s)? I'd like to know if we have the option of using the Data Flash for built-in test logging on our SPC560B64.
Options
‎2015-06-29 7:54 AM
Posted on June 29, 2015 at 16:54
Hello Kevin ,
SPC560B has a NOR FLashThe Erase Cycles Allowed should be between 10000 and 100000. Best Regards Erwan
Options
‎2015-06-29 7:54 AM
Hello Kevin ,
SPC560B has a NOR FLashThe Erase Cycles Allowed should be between 10000 and 100000. Best Regards ErwanOptions
‎2015-06-30 7:29 AM
Posted on June 30, 2015 at 16:29
Thankyou.
Kevin
