could you show me the memory map of the device SPC584B60E3, what is the exact size of this divice?
‎2021-03-28 6:52 PM
I have the memory map on page 76 of this manual,
but it is for 2M flash memory, for my device it is 1M, i have read out the MCU ID Register #2(SIUL2_MIDR2), one value is 0Xb0004200(1M), but actually i found the flash all be programmed correctly to 2M.
‎2021-04-01 6:09 PM
‎2021-03-29 2:51 AM
Parts using the same die, but only portion of it tested.​
‎2021-03-29 11:40 PM
Hi DeLorean,
thanks for your reply. so do you know for the 1M flash chip, whether the address from 0x010C0000 to 0x011BFFFF should not be included. thanks a lot.
‎2021-03-31 2:56 AM
the SPC584B60 has a flash size of 1MB. You can find the details within the related Datasheet at this link, at pag.129 Table 73.
Regards,
Luigi
‎2021-04-01 6:09 PM
Hi Luigi,
thanks, this is helpful.
thanks a lot
Luke
