simone
Compability issues with UDE
  • January 22, 2016
  • 1 reply
  • 642 views
Posted on January 22, 2016 at 16:17
I'm using the MPC5643L from nxp on the modular+minimodule board. Do you know if it is possible to program it with  http://www.st.com/web/en/catalog/tools/PF258744  using the UDE debugger? I apparently can connect but I can't debug and I don't know if it is possible or not.
Thank you very much.
    1 reply
    Erwan YVIN
    Posted on January 25, 2016 at 11:34
    Hello Simon ,
    I think that it should work ...(same device)
    Maybe you need to create a new workspace with Freescale reference with PLS to take the hand.
    (cf screenshot)
    Could you give your minimodule reference ?
    Could you check if PLS FTDI A/B are available in your Windows (Device Manager) after switch-on the board ?
    Best regards
    Erwan
    ________________
    Attachments :
    2016-01-25_113129.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qVW6&d=%2Fa%2F0X0000000bnx%2FBaYroynXZgMeZ1iv_ZsOQ3QrbLlXHJb3DU_7mmGguM8&asPdf=false
