2015-04-06 01:21 AM
Hello EveryBody,
I'm try to build a project using the compiler : codesourcery for PowerPC. is their any tutorial or guidline to help .to use codesourcery witch eclipse to compile a project for SPC56 MCU ???2015-04-07 02:40 AM
That compiler does not support the VLE instructions set so it cannot be used with e200z cores. Some SPC56 devices can also use book-e code (SPC56x devices with e200z3 and e200z4 cores) but the scenario is not supported and it has been removed entirely from SPC57x devices. Giovanni
