CFlash module example code for SPC560B60L7
Hank Im
Posted on January 31, 2018 at 01:17
Hello!
I'd like to use CFlash module without using C90LC Standard Software Driver(SSD).
But I don't konw how to configure it.
Could you provide me an example code?
i.e) CFlash initialize, CFlash Erase, CFlash Write, etc...
Thank you.
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
Erwan YVIN
Posted on February 01, 2018 at 11:28
Hello Hank ,
Officially , we useC90LC Standard Software Driver(SSD)
we have just an example for dflash coming from old posts
Best regards
Erwan
________________
Attachments :
spc5_dflash.c.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hy4w&d=%2Fa%2F0X0000000b3i%2FBgicYvVwkEA8migGsDEqekerFan.EmEtJojyRPkYKBY&asPdf=false
spc5_dflash.h.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hy4r&d=%2Fa%2F0X0000000b3c%2FU89O0DvE0YbNG3HcmjYSfvh.XaG_3xPOV5RaeQ020n0&asPdf=false
Posted on February 02, 2018 at 03:43
Hello, Erwan Y
Thank you for your reply.
But i already had the Dflash sample code. My Dflash sample code is the same as what you attached.
I need a CFlash sample code.
If the CFlash module configure is the same as the DFlash sample code,
Should i change SPC5_DFLASH_BASE address to SPC5_CFLASH_BASE address in sample code?
Thanks.
