2021-04-14 06:34 PM
would you check and explain what is different in between USBLC6-2P6 and USBLC6-2P6/J
2021-04-15 03:53 AM
Pictured here, guessing a packaging designation or engineering rev.
2021-04-14 11:33 PM
Where did you find the ordering code USBLC6-2P6/J?
/Peter
2021-04-15 02:27 AM
Hi Peter,
We have received the part as the manufacturer label showing both MPN type, so would you help to check and explain the difference, thanks,
2021-04-15 02:35 AM
You didn't upload any picture.
For privacy reasons, please do not use your e-mail account to reply with an e-mail, as this will make your contact details visible to the entire community. Right now, the best way to do this is to log in with a web browser.
/Peter
2021-04-15 03:53 AM
2021-04-15 04:39 AM
The type number USBLC6-2P6 is the is the actual designation, while the suffix /J in the 2nd line is used for internal follow-up and indicates the place of manufacture.
To answer your question: no, there is no difference, it is the right device if you have ordered USBLC6-2P6.
Good luck!
/Peter
