Vintage ST/SGS-thomson component ID
Cooldeepseaaudio
 looking to identify this IC, it's most likely from the mid to late 70s and my own hunt has turned up nothing, I would expect it to most likely be some form of amplifier as it is used in a preamp circuit.
Any help would be appreciated, thanks!
Fergus.
10 REPLIES 10
Based off the pinout I believe it is the LS150, power and ground to the correct pins anyway and everything else looks reasonable so far, looks like one is being used as the Expandor and one as a compressor potentially.
