2011-11-18 6:17 AM
Dear Forum Members,
I�d like to share a few tips on the usual process I use to select an Op Amp based on pre-defined technical requirement.
The tool I use more often is the product selector, which can be accessed by clicking on the following icon from ST home page:
Here is also direct link to the
http://www.st.com/stonline/stappl/productcatalog/app?page=productSelector
The next step is then to use the �Filter Panel� in order to refine the technical requirements.
Tip1: use the arrows to see all the filtering parameters.
Tip2: use the icon close to the parameter name to toggle the filter type between �tick case� and �slider�.
In my typical Op Amp selection, I would firstly apply filter on the more obvious (and restrictive) parameters, like voltage rating �Vcc�, �number of channel� or �automotive grade�.
Then once the selection is narrowed to a limited number of components, I would use the sorting option, by clicking on the parameter. A red arrow indicated if the list is sorted by ascending or descending order. For instance sorting by maximum supply current:Don�t hesitate to let us know your comments about the product selector and if there are additional features you would like to see implemented.
Best regards.
#comparison-operational-amplifier #product-selector-op-amps-filter2011-11-20 2:07 PM
I use several operational amplifiers from different suppliers in my designs.How can I find equivalent operational amplifiers from STMicro?Thank you.2011-11-22 7:59 AM
Dear Jean,
In order to select an equivalent Operational Amplifier from ST portfolio, you can either:
- use the product selector as explained in previous post, by typing in your technical requirements
or
- use the cross reference tool provided in ST website.
To find the cross reference: go first to ST home page, select the ''Search'' tab on top-right of the screen, type your target device in the ''cross reference'' field.
2011-11-29 2:29 AM
Dear Forum Members,
Another tip in your operational amplifier selection process: you may need to compare two or more devices, and ST website has a dedicated feature for this.Here?s how to proceed: first go to the product selector as explained beforehttp://www.st.com/stonline/stappl/productcatalog/app?page=productSelectorThen click on the comparison icon located on the bottom right of the table.
