Does the APWorkbench tool supports any scripting language?
Options
2013-11-11 4:51 AM
Posted on November 11, 2013 at 13:51
Options
2013-11-12 6:28 AM
Posted on November 12, 2013 at 15:28
Yes, the tool supports a scripting language enabling operations such as I2C register read/write, IIR coefficient read/write, simple loops, pauses, dumping of the relevant information and monitoring of specific bits of supported devices.
Scripting commands can be loaded from a file on disk, refer to the ''Run script...'' item in the ''File'' menu. A convenient shell interface is also included in order to issue commands - through the ''Log View'' button. Typing ''help'' will list the available commands. Note: the tool can also be used as a generic I2C I/O interface - with logging capabilities - by selecting the ''APWLink Audio Interface'' in the Launch Wizard startup dialog. required.
