Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
APWorkbench
Posted on June 18, 2018 at 09:14Hi,I am trying to download AP workbench but it says file does not exist, please help me where to download this file.Regards,
TDA7265B free samle
Posted on April 08, 2018 at 21:27Hi, I need a free sample of TDA7265B. It is a class-AB two-channel power amplifier. I didn't find in a list of free samples of integrated circuits of its class. There is a TDA7265 chip, it is very similar but not the...
why the ADS model of PD84008-E can't be installed into ADS?
Posted on March 27, 2018 at 06:14Hello      I am trying to design a 2w transmitter with frequency range of 72mhz to 73mhz, I want to use PD84008-E;I've download  it's ADS model, but I am failed to unzip it into ADS(as below picture), because no lib....
L9663-1-IBIS Model Required
Posted on June 23, 2017 at 13:50Hi,IBIS model not available for this  part number . L9663-1Where can i find the IBIS model ?Is there any I/O model i can use for this part number?Thanks and RegardsArunkumar K#l9663-1
STDP 9320 Athena
Posted on March 14, 2018 at 05:39Hello, i am using BRD TV Board (Athena STDP9320 based), I want to know, which IR Glasses is supported by BRD Board.
ESR/LCR Precision Meter design and implementation...
Posted on February 11, 2018 at 18:17Hello guys,I have recently found myself in a situation where I needed an ESR/LCR meter to do some troubleshooting of a PSU for an old TV set. As usual, the first thing that came to my mind was 'why not build one m...
Zaher by Senior II
  • 1315 Views
  • 0 replies
