What is #error cgstm8 .... PANIC! MOVCNT
MRodr.12
What is the meaning and root cause of following error:
#error cgstm8 xsnprintf.c:195 >123<@generate() PANIC! MOVCNT
I am trying to build a custom printf routine. This shows up only after I change the type of some parameters.
Try looking at the offending source code lines to understand the #ifdef tree or whatever that go you to the #error line...
