UART1 example with reference to chm file(stm8s_fwlib_um)
dipti
Posted on June 23, 2010 at 08:47
mozra272
Posted on May 17, 2011 at 15:09
Hi ,
Regarding the reference manual the BRR values are evaluated using fMaster = 24Mhz and in your case you have fMaster = 16MHz.
Can you please check another hypertherminal tool (try Hercules.exe) and your hardware connection.
You can download Hercules.exe from this link:
http://hercules-setup.hw-group-s-r-o.qarchive.org/
If the Hypertherminal is not correctly configured you should receive data but is not correct.
The expected data ''HyperTerminal Interrupt: UART1-Hyperterminal communication using Interrupt''
Best Regards
mozra
