2026-01-22 10:07 PM - last edited on 2026-01-23 2:58 AM by Andrew Neil
Split from Issue with UART/USB Rx interrupt in STM32F407VGT6 and using DP83848 LWIP stack - which was solved some time ago.
@Satya_VVM can you help me with the same project.
I am working on UART to ethernet convertor but I am not able to find any reference .
2026-01-23 2:59 AM
@aj8791 wrote:I am working on UART to ethernet convertor .
So what have you done so far? Where are you stuck?
How to write your question to maximize your chances to find a solution
2026-01-23 5:25 AM
2026-01-23 5:58 AM
@Satya_VVM wrote:
Hi… Andrew
It's not me that was asking - it's @aj8791
