STVP fails to load \TOOLS.CNF
Maciej Godek
Posted on April 26, 2017 at 13:58
I've been trying to connect my application through ST-LINK according to the
http://www.st.com/content/ccc/resource/technical/document/user_manual/90/cb/42/ef/2e/53/46/75/CD00060186.pdf/files/CD00060186.pdf/jcr:content/translations/en.CD00060186.pdf
, but when I invoke
ESelectHard('ST-LINK', 'SWIM', FALSE)
it returns 0, and
CGetLastError
provides the following message:
File \TOOLS.CNF : No such file or directory
The file TOOLS.CNF is clearly present in the same directory as the .dll files that I successfully manage to load (eprcore60.dll, dbca60.dll, lef60.dll and file60.dll).
What is the policy of s
Maciej Godek
Posted on April 26, 2017 at 14:02
I accidentally sent the incomplete question and can't find a way to edit it.
I wanted to ask, what is the policy of searching for the .cnf files in the file60.dll -- are the paths hard coded, or are they relative to the dll files, or can their path be set somehow?
I enclose the complete source code of my attempts below:
#include 'stdafx.h'
#include <windows.h>
#include <conio.h>
#ifndef MAX_PATH
#define MAX_PATH 260
#endif // MAX_PATH
using namespace std;
#define WARN(msg, ...) fprintf(stderr, msg '\n', ## __VA_ARGS__)
#define WWARN(wmsg, ...) fwprintf(stderr, wmsg L'\n', ## __VA_ARGS__)
typedef int(*EAllAccess_t)(DWORD dwAreaId);
typedef int(*EAreaAccess_t)(DWORD dwAreaId, long FirstAddr, long LastAddr);
int(*ESelectDevice)(const char *szDevice);
int (*ESelectHard)(const char *szCard, const char *szProtocol, BOOL bDemo);
int(*ESelectPort)(const char *szPort);
int(*ESetPreferences)(int iPreference, BOOL bState);
int(*ESetProtection)(const char *szProtectMode, BOOL bState);
int(*ECheckSum)(DWORD dwAreaId, long *FileCheckSum, long *MemoryCheckSum);
int (*EGetId)(const char *szName, DWORD *pdwId);
char *(*EGetImagePtr)(DWORD dwAreaId, long *MemSize);
int(*ECloseComm)();
char *(*CGetLastError)() = NULL;
char *LastErrorMessage()
    if (CGetLastError)
        return CGetLastError();
    return 'unknown error';
#define TRY(action) if(!(action)) { WARN(# action ' failed: %s', LastErrorMessage()); return; }
EAllAccess_t EBlankAll;
EAreaAccess_t EBlankArea;
EAllAccess_t EEraseAll;
EAreaAccess_t EEraseArea;
EAllAccess_t EProgAll;
EAreaAccess_t EProgArea;
//EAllAccess_t EReadAll;
EAreaAccess_t EReadArea;
EAllAccess_t EVerifyAll;
EAreaAccess_t EVerifyArea;
void LoadLibraries()
    HINSTANCE eprcore, dbca, lef, file;
    TRY(eprcore = LoadLibrary(L'eprcore60.dll'));
    TRY(dbca = LoadLibrary(L'dbca60.dll'));
    TRY(lef = LoadLibrary(L'lef60.dll'));
    TRY(file = LoadLibrary(L'file60.dll'));
    TRY(CGetLastError = (char *(*)()) GetProcAddress(dbca, 'CGetLastError'));
    TRY(ESelectPort = (int(*)(const char *))GetProcAddress(eprcore, 'ESelectPort'));
    //TRY(EReadAll = (EAllAccess_t)GetProcAddress(eprcore, 'EReadAll'));
    TRY(ESelectHard = (int(*)(const char *, const char *, BOOL)) GetProcAddress(eprcore, 'ESelectHard'));
    TRY(EReadArea = (EAreaAccess_t)GetProcAddress(eprcore, 'EReadArea'));
    TRY(EVerifyAll = (EAllAccess_t)GetProcAddress(eprcore, 'EVerifyAll'));
    TRY(EVerifyArea = (EAreaAccess_t)GetProcAddress(eprcore, 'EVerifyArea'));
    TRY(EProgAll = (EAllAccess_t)GetProcAddress(eprcore, 'EProgAll'));
    TRY(EProgArea = (EAreaAccess_t)GetProcAddress(eprcore, 'EProgArea'));
    TRY(EEraseAll = (EAllAccess_t)GetProcAddress(eprcore, 'EEraseAll'));
    TRY(EEraseArea = (EAreaAccess_t)GetProcAddress(eprcore, 'EEraseArea'));
    TRY(EBlankAll = (EAllAccess_t)GetProcAddress(eprcore, 'EBlankAll'));
    TRY(EBlankArea = (EAreaAccess_t)GetProcAddress(eprcore, 'EBlankArea'));
void ReadMemory()
    DWORD PROGRAM_MEMORY, DATA_MEMORY;
    TRY(ESelectHard('ST-LINK', 'SWIM', FALSE));
    TRY(ESelectDevice('STM8L15xC6'));
    TRY(ESelectPort('USB'));
    TRY(EGetId('PROGRAM MEMORY', &PROGRAM_MEMORY));
    TRY(EGetId('DATA MEMORY', &DATA_MEMORY));
    WARN('PROGRAM MEMORY = %d, DATA MEMORY = %d', PROGRAM_MEMORY, DATA_MEMORY);
int main()
    TCHAR pwd[MAX_PATH];
    _wgetcwd(pwd, MAX_PATH);
    WWARN(L'Current Working Directory: %s\n', pwd);
    SetDllDirectory(L'C:\\st_toolset\\stvp');
    LoadLibraries();
    ReadMemory();
    getchar();
    return 0;
Maciej Godek
Posted on April 26, 2017 at 16:19
I managed to solve the problem by invoking the 'CSetWorkingDir' function. Sorry for the noise.
