2012-05-10 5:25 AM
Im using STVD v 4.2.1 patch 2 on my STM8 project, the problem is when I want to compile, it gets stucked annoyingly for around 10 seconds then it starts to save first and compile the codings normally. I couldnt manage to get rid of this 10 seconds stucking period so far. This happens actually when STVD is trying to save the changes. If someone has any idea how to fix it or someone has had the same issue before..? Please, any help will be appreciated!Kadir. #stvd-slow-while-compiling2012-05-15 7:40 AM
2012-05-15 11:57 PM
Hi Mac,
I upgraded STVD to the latest version and excatly the same thing happened again. Finally, I got a solution by creating a new workspace with the same .c files then apparently It worked fine. So it seems that some setting of STVD had been changed due to some reason.. Hope it works for you too.Kadir.
