Programming an in circuit STM8S105K6T6C MCU Via UART
FEsfa.1
Using STLINK-V3SET. Please Note in circuit STM8S105K6T6C  embedded board has these pins GND, RX, TX , VCC. Many thanks
4 REPLIES 4
I'd guess you'd just use the VCP COM port with Flasher STM8..
https://www.st.com/resource/en/user_manual/cd00201192-stm8-bootloader-stmicroelectronics.pdf
https://www.st.com/en/development-tools/flasher-stm8.html
FEsfa.1
Thank you. I am new to this field would you please elaborate more?
Philipp Krause
Senior III
There also are alternatives to the Windows-only FLASHER-STM8, e.g.:
https://github.com/gicking/stm8gal
RKong.1
I have been programming the STM8S105C6 chip using a STLinkV2 programming cable and the SWIM interface (you need to connect to SWIM, RESET, GND) and stm8flash. In recent days I have been experimenting with programming using UART and the built-in bootloader with limited success.
