Need STM8L development Guidance
‎2021-01-30 1:54 AM
I have posted already that I am using STM8152R8 nucleo board
I have downloaded cosmic c compiler and it's license file too. I have also downloaded the STM8L library (en.stsw-stm8016) from the ST website. I have included the source files and include files through these libraries files and I have Also uncommented the microcontroller which I am using in STM8l.h file, still, I am getting errors On STM visual Develop that
"select the microcontroller in STM8L.h "
Also "STM8Lconf.h" is not there in library files, this also showing me an error.
Please suggest me any solution.
Thanks and regards
Deoyani
‎2021-01-30 2:49 AM
Hi DJosh.0,
Can you specify if you have created your own STVD project?
If so, and to be more precise, the library STM8L15x-16x-05x-AL31-L_StdPeriph_Lib (en.stsw-stm8016) contains the following header:
\Libraries\STM8L15x_StdPeriph_Driver\inc\stm8l15x.h
This \inc directory has to be configured in the STVD C Compiler settings (Project -> Settings -> C Compiler and Additionnal include directories
Your project must contain the following file
\YourProject\stm8l15x_conf.h"
You can also use a template project that is included in the library and that is already configured.
‎2021-01-30 4:14 AM
Thank you for answering me
I have configured the \inc directory in the STVD C compiler setting( project->settings->c compiler -> category->preprocessor-> additional include directories)
also, I have included "stm8l15x_conf.h" in my project through the template project.
still, I am getting an error that "Please select first the target STM8L device used in your application (in stm8l15x.h file)".
also, I will try to edit stm8l15x.h file then it shows access denied ->this file is read-only. (access denied is showing in STVD)
I have said it before that I have Also uncommented the microcontroller which I am using in stm8l15x.h file (I have edited this in notepad and saved stm8l15x.h file in another folder from this folder I am using it )
following Errors, I am getting now :
#error "Please select first the target STM8L device used in your application (in stm8l15x.h file)"
#error cpstm8 ..\..\stm8l15x-16x-05x-al31-l_stdperiph_lib\libraries\stm8l15x.h:2896 can't open stm8l15x_conf.h
#error cpstm8 ..\..\stm8l15x-16x-05x-al31-l_stdperiph_lib\libraries\stm8l15x_stdperiph_driver\src\stm8l15x_wwdg.c:122(14) missing prototype
#error cpstm8 ..\..\stm8l15x-16x-05x-al31-l_stdperiph_lib\libraries\stm8l15x_stdperiph_driver\src\stm8l15x_wwdg.c:140(14) missing prototype
#error cpstm8 ..\..\stm8l15x-16x-05x-al31-l_stdperiph_lib\libraries\stm8l15x_stdperiph_driver\src\stm8l15x_wwdg.c:159(14) missing prototype
#error cpstm8 ..\..\stm8l15x-16x-05x-al31-l_stdperiph_lib\libraries\stm8l15x_stdperiph_driver\src\stm8l15x_wwdg.c:190(14) missing prototype
what should be the solution to this problem.
please give me suggestion
thanks and regards
Deoyani
‎2021-01-30 4:45 AM
You will have to allow the modification of the entire directory containing the STM8L library and the projects it contains.
As you are under Windows, make a right click on the directory and in the properties, uncheck Read Only and do this for all the sub-folders.
It seems that even if you uncomment the device in the stm8l15x.h file, as your file is read-only, this is not taken into account by the pre-processor.
‎2021-01-30 4:58 AM
in addition, you get compilation errors:
and you must also uncomment the following line:
Into stm8l15x_conf.h (which should not also be read only)
#include "stm8l15x_wwwdg.h"
and also all those that your project uses
Hope it will resolve compilation issues
‎2021-01-30 6:14 AM
hello,
I have done what you have said to me still I am getting an error, I am sending you the screenshot
I am not getting error in build tab but an error in the tools tab please check this in my screenshot (at the bottom in the output window).
thanks and regards
deoyani
‎2021-01-30 6:15 AM
also, I am getting an error while debugging the code
I am attaching the screenshot
please find the attachment and give me the solution
thanks and regards
Deoyani
‎2021-01-30 6:57 AM
#error : "Unsupported Compiler!"
Your project is not build, some project settings are not set properly.
Is it a project made by you ?
Step1: Try to open, build and debug an existing STM8L template workspace into
\stm8l15x-16x-05x-al31-l_stdperiph_lib\Project\Project_template\STVD\Cosmic\STVD_workspace.stw
Step2: Check all tabs settings into template project, and compare with your settings
Step 3: Read STVD User Manuel https://www.st.com/resource/en/user_manual/cd00004556-st-visual-develop-stvd--stmicroelectronics.pdf
‎2021-01-30 8:39 AM
Yes, I am doing with template folder still I am getting the same issue.
can you please help to resolve the following issue which is in the attached screenshot
I am getting this issue after going to tools-> options
thanks and regards
deoyani
‎2021-01-30 9:09 AM
No need to set any path here in STVD Options Tab.
Check if Cosmic STM8 FSE is correctly installed in C:\Program Files(x86)\COSMIC in your computer and the path is need in Workspace Project Settings -> General Toolset Info Tab
Best regards
