How to programming ROP option byte via swim?
‎2011-03-16 8:09 PM
#programmer #stm8- Mark as New
‎2011-05-17 6:12 AM
to write on option byte area you need to set7reset bit 7 of FLASH_CR2/FLASH_NCR2 register. Remenber to enter keys on FLASH_DUKR register before.
If ROP is activated, remove it writing 00h on 4800h then reprogram option bytes as you prefer. Note that removing ROP, whole program memory is erased.
brazov2
‎2011-05-17 6:12 AM
Thanks Mr brazov.
I Solved this problem
STM8L15x devices are some different than others. My code is below. swim_enter(); delay_10xus(Time_us(10000)); icp_eeprom_unlock(); swim_write_register(STM8_FLASH_CR2, (STM8_FLASH_CR2_ERASE)); swim_write_register(0x4800, 0x00); delay_10xus(Time_us(6000)); swim_write_register(STM8_FLASH_CR2, (STM8_FLASH_CR2_OPT)); swim_write_register(0x4800, 0xAA); Thanks a lot..- Mark as New
‎2011-05-17 6:12 AM
Hi Kim yongsu,
Please could I have a copy of your code, I am trying to make my own programmer but I cannot make it yet, I would like to know if you can share your code to implement it in my programmer. Thank you very much- Mark as New
‎2011-05-17 6:12 AM
Do you have any schematic for such a STM8 programmer? I'd like to build one for me. Thanks- Mark as New
‎2013-10-18 3:00 AM
Hello!
Help please!STM8S003F3The sequence of operations Read out protection ENABLED'' write_Byte(FLASH_DUKR,0xAE); write_Byte(FLASH_DUKR,0x56); write_Byte(FLASH_CR2,0x80); write_Byte(FLASH_NCR2,0x7F); uint32_t time_set = 3000; while(time_set-- != 0) { if(read_Byte(FLASH_IAPSR)&(1<<3)) { wait_time(2000); write_Byte(OPTION_BYTE,0xAA); } }''Upon reboot, the MC, reading OPTION_BYTE returns 0xAA,after the restart, reading OPTION_BYTE and the Flash returns 0x71The sequence of operations Read Out Protection DISABLED'' write_Byte(FLASH_DUKR,0xAE); write_Byte(FLASH_DUKR,0x56); write_Byte(FLASH_CR2,0x80); write_Byte(FLASH_NCR2,0x7F); uint32_t time_set = 3000; while(time_set-- != 0) { if(read_Byte(FLASH_IAPSR)&(1<<3)) { wait_time(2000); write_Byte(OPTION_BYTE,0x00); } }''After recording OPTION_BYTE MC stop responding to any action. SWIM interface does not work.
