How to generate .bin file from STVD
H_H_11
Hi STM8 Team,
I can see STVD generates .s19 , .sm8 files. I want to generate .bin file.
I had tried it by adding the following line in Post-Build section:
chex -o $(OutputPath)$(TargetSName).bin
But this did not work. Could you please guide me on how to generate .bin in STVD?
Thanks,
Hrithik
Artur IWANICKI
You are right. Within chex converter description there is no binary files, only hex and s19. This last one is default output file format.
In fact chex is a tool provided by Cosmic toolchain.
I do not see any built in hex2bin converter within STVD neither.
4 REPLIES 4
Artur IWANICKI
There is no indication to the input file (.sm8) which needs to be converted into .bin.
Could you please try instead:
chex -o $(OutputPath)$(TargetSName).bin $(OutputPath)$(TargetSName).sm8
H_H_11
Hi @Artur IWANICKI​ ,
Thanks for the response.
I tried your suggestion and .bin file is getting created, but the content of .bin file is exactly similar to .s19.
Does STVD support .bin format?
Thanks.
Artur IWANICKI
Will check another way to do this.
