how to create library and hide its symbols
haukeye
Posted on May 17, 2016 at 16:56
Hi All.
When using the STM 32f407 board.
I want to create a library at keil uvision,based purely ANSI C.
i just want the user to have an api h file and the library ,when i want all the library functions and variables (and code...) to be hidden.
I created the library project and still i see the variables and function.
I want this library and h file to be used by other projects at keil uvision.
Posted on May 20, 2016 at 19:29
Wrong forum, but you'd want to process the object/library files and obfuscate or remove the material you don't want to be visible.
