CxSTM8 v4.3.5 now supports STM8L eeprom
luca239955_stm1_st
Senior II
Posted on September 29, 2010 at 15:03
4 REPLIES 4
641351125
Posted on May 17, 2011 at 15:10
Luca
the manual describe like this''you must link with the extra library libl.sm8 placed
before
the standard libm.sm8'',but how to do it in the STVD? I would like to know the setting.
Calvin
luca239955_stm1_st
Senior II
I think the STVD team is making the necessary modifications so that the automatically generated linker file works ok, but I don't know if this has been released yet.
Whatever way, if your STVD does not generate a correct linker file automatically, you must edit it by hand.
Luca
lowpowermcu
Hi luca,
What is the utility of using such memory types ?
I am used to play with mcu and never I got such types ?
what is the advantage of placing varaibles there ?
Perhaps such questions should be asked to ST, why they are implementing eeprom in their micro ? (I think that STM32F sereis doesn't embedd eeprom)
Thanks in advance.
with regards,
MCU Lüfter
luca239955_stm1_st
Senior II
you would usually store in EEPROM those data that you don't want to loose when you turn off the application: telepohone numbers in a mobile phone, running statistics in a car engine... a lot of examples could be made.
Luca
