Cosmic
krzysztof239955_st
Posted on October 02, 2009 at 06:41
Cosmic
krzysztof239955_st
Posted on May 17, 2011 at 15:04
I use ST Visual Develop with Cosmic compiler. If I declare the local variable (in main.c), the returned value never correct, if it is declared as global variable, the returned value is correct, why?
luca239955_st
if you don't *see* the value you expect in a local variable is probably just an optimization. If the value is actually not correct (for example in a subsequent use of the local variable) than it is another issue.
Please post an example to clarify.
Luca (Cosmic)
krzysztof239955_st
Hi _luca,
It pretended me the problem to be dissolve.
krzysztof.skoczek
