Can't option byte programming
skef2009
Posted on August 06, 2013 at 15:27
Hello!
I'm can't programming option byte in the stm8s105c6t6 into my board stm8s-discovery.
This code:
 mov FLASH_DUKR,♯$56;
 mov FLASH_DUKR,♯$AE;
 ld A,♯%00001100; IWDG_HW and LSI_ EN set
 ldw X,♯$4805
 ld (X),A
 incw X
 cpl A
 ld (X),A
 Here I read option bytes,  they unchanged. Can you Help me?
#stm8 #option-bytes
mtien888
Posted on September 04, 2013 at 20:41
I have similar problem that I can't change option byte(wait state) by program for STM8S207.
jdf25252
Posted on September 05, 2013 at 16:58
ST manuals can be somewhat obscure. First check section 4.5.3 - Note that the access method is the same as for data memory using 0xAE then 0x56 and then setting the OPT bit in the FLASH_CR2.
 mov FLASH_DUKR,#$AE;    FLASH_RASS_KEY2
 mov FLASH_DUKR,#$56;    FLASH_RASS_KEY1
 mov FLASH_CR2,#$80;    OPT bit to enable Option byte programming
 mov FLASH_NCR2,#$7f;
 ld A,#%00001100; IWDG_HW and LSI_ EN set
 ldw X,#$4805
 ld (X),A
 incw X
 cpl A
 ld (X),A
Hope this works for you
jdf
