STM8 MCUs
Discuss STM8 microcontrollers, including SWIM, USART configurations, RTC usage, ADC issues, and debugging.
Rohs
Posted on December 28, 2010 at 21:53Hello I am trying to find out if this item is ROHs anyone know how to tell? The part number is http://netsemi.com/p-607159-supervisory-circuits-lo-pwr-vltg-detector.aspx
tyler23 by Associate
  • 608 Views
  • 1 replies
Errors STVD
Posted on February 04, 2011 at 17:32Hello, can you help me?I can not build any code with STVD.I installed COSMIC compiler 32K.every time he gives me the following error message:----------- Project stm8s105 - STM8 Cosmic - Configuration Debug -------...
nad by Associate II
  • 1072 Views
  • 3 replies
comunication between color sensor and stm8s-discovery with i2c
Posted on February 01, 2011 at 16:09Hi!I want that stm8s-discovery read color  using a color sensor (ADJD-S371-QR999).I use i2c protocol in this way:I2C_GenerateSTART(ENABLE);    while(!I2C_CheckEvent(I2C_EVENT_MASTER_START_SENT));</span></div>     ...
solved
Posted on January 31, 2011 at 13:59solved
Issue the command BRES and register ITC->ISPR
Posted on January 31, 2011 at 05:04why reset command BRES does not work one bit of the register ITC->ISPR (does not reset the bit) in the simulator works in real mcu does not work. - However, the command BSET works in the simulator and in mcu --- e...
I2C Discovery Board
Posted on January 03, 2011 at 09:49Hi,I'm trying to write a driver for i2c communication for the Stm8L discovery board.After the Start (Master mode) is generated if I try to send an adress nothing happens and the i2c clock is hung at low level.I an ...
jfelix by Associate II
  • 598 Views
  • 1 replies
Int2str function improvement
Posted on June 15, 2010 at 17:25Dear friends, this improved version of the ''int2str'' function will solve a bug present in the original version provided with the hyperterminal example though it is used nowhere in that example. I'm working on an app...
spiovan9 by Associate II
  • 1222 Views
  • 7 replies
