STM8 MCUs
Discuss STM8 microcontrollers, including SWIM, USART configurations, RTC usage, ADC issues, and debugging.
IO ports
Posted on November 12, 2010 at 14:33I intialize Port A3 as a push pull output but when I call writeHigh or writeLow nothing changes on that output.  I am using a multimeter to read the output on pin 9 of cn1 charles
carnett1 by Associate II
  • 1160 Views
  • 5 replies
Stm8s Discovery project with stts75 sensor and µoled display
Posted on November 30, 2010 at 10:31 hello all Please find attached file source code and resources on my recent personal project. Stm8s-Discovery is interfaced with astts75 chip (digital I²C temprature sensor) and a graphic serialdisplay of...
RomainR. by ST Employee
  • 484 Views
  • 1 replies
HyperTerminal example re-work
Posted on July 20, 2010 at 12:07Hello all , After all your feedbacks on the HyperTerminal example, we're currently reworking the package (documentation and source code) . the new sources (um0884.rar) are in attachement of this post . in this correct...
Grom by ST Employee
  • 1712 Views
  • 9 replies
Type conversions
Posted on November 22, 2010 at 19:15I am using the STM8S-discovery card and I want to convert a long to a floting point and also a float or double to an ASCII  string.  If I use a very common conversion such as atof to convert a string to a float it...
  • 902 Views
  • 4 replies
Stm8s + pressure sensor
Posted on November 19, 2010 at 14:50Hi,i'm new in developping , so i was wondering if anyone can help me developping the code of a pression sensor relied to the Stm8s.Can anyone give me the functions and pins to use.Thank you.
kinggnl by Associate
  • 680 Views
current on smtss-105c6
Posted on November 18, 2010 at 22:43I would like to find the spect sheet for stm8s 105c so I can see what load current is availabile on the i/o ports.  charles
  • 506 Views
  • 1 replies
SWIM error [30007]
Posted on November 17, 2010 at 07:30SWIM error [30007]
anirban2 by Associate
  • 587 Views
  • 0 replies
UM0845.pdf
Posted on November 15, 2010 at 17:54I have downloaded some PDF files from ST but now I need to download LM0845.pdf and they changed their web site and I cannot ind that file.  Can anyone help me?  Please give me the link to that file or the links to...
  • 575 Views
beeper on stm8s-discovery
Posted on November 12, 2010 at 19:20I am using hyperterminal.com and stm8s_beep.c and when I go thru the hyperterminal toturn on th ebeeper at 2Khz I go nothing accross the piezo sounder.  I even look at itwith a scope and nothing.  What sould I see...
  • 555 Views
  • 0 replies
