STM8 MCUs
Discuss STM8 microcontrollers, including SWIM, USART configurations, RTC usage, ADC issues, and debugging.
www.st.com
Posted on May 02, 2018 at 09:34http://www.st.com/content/st_com/en/products/microcontrollers/stm8-8-bit-mcus/stm8s-series/stm8s103-105.html?querycriteria=productId=LN754On this page, the flash/ram should be 8k/1k on STM8S103F3 and STM8S103K3
Resolved! Problem in displaying a number on char LCD displays
Posted on May 01, 2018 at 12:39Hi.I was working with my new stm8s105 MCU trying to get started with the timers.But every time I use the command to display the time on the LCD the same number showed every time.I thought that the problem is my timer c...
The clocks each command takes
Posted on April 27, 2018 at 19:52Hi.I wanted to know that for example how many clocks a while loop takes.Do you have any ideas or any articles on this matter?
STM8L052R8 NRST ESD PROBLEM
Posted on April 25, 2018 at 03:39Hello..I am using a circuit board using the STM8L052R8.This board generates the voltage to be applied to MCU after applying 4.8VDC voltage by using 3.3VDC regulator.IWDG and BOR are used in the firmware.However, when...
Interrupt that will not expected
Posted on April 23, 2018 at 03:59Hello,- MCU : STM8L101K3I am using Port A.2 for interrupt and Port D.2 for general gpio.GPIO_Init(GPIOA,GPIO_Pin_2, GPIO_Mode_In_FL_IT); EXTI_SetPinSensitivity(EXTI_Pin_2, EXTI_Trigger_Falling); GPIO_Init(GPIOD, GPIO...
STM8 Vcap voltage
Posted on April 21, 2018 at 07:31Hi everybodyI have designed my own pcb stm8 based on discovery board stm8AF52 5v power I can program it easily without any problem but Vcap voltage is 2.4 instead 1.8 what is the problem here?thanks for your help in ...
What is the reliability of the RTC?
Posted on April 21, 2018 at 14:35Hello everyone,Very much I ask to respond who knows. Whether methods are applied of providing increased reliability of real-time timers, for example redundant coding or majority calculations. And what are the values ...
www.colecovision.eu
Posted on February 11, 2018 at 20:04Another comparison of C compilers for the STM8 About two years ago, I did a comparison of C compilers for the STM8. It can now be found at http://www.colecovision.eu/stm8/compilers-2016.shtml.I also redid the comp...
