Unable to run stm32cubeprogrammer due to Java issue
‎2020-08-06 6:31 AM
I get the following error when I try to run STM32CubeProgrammer both as admin or non-admin.
My system details: Windows 10
Java versions :
I have tried using cubeprogrammer 2.5 as well as 2.4 and I get the same error in both cases. Please let me know if any of you faced this and what is the solution to this.
error message: CubeProgrammer_API or one of it's dependencies is missing.
When i reinstall CubeProgrammer, it works for the first time I open the software but if I close and try to open it again, I face the above errors
Thank you
- Labels:
STM32CubeProgrammer
‎2020-08-06 7:35 AM
Here are the Java versions I tried enabling/disabling
‎2020-08-06 7:36 AM
Here is the error I faced.
‎2020-11-24 12:26 AM
I have same issue.Did you solve it?
‎2020-11-30 11:36 AM
i have the same issue. no solution for me yet. did you get it ?
