Demos not running on STM32F769i-DISCO on Cubeprogrammer 2.6.0
‎2020-11-19 5:47 PM
Almost all demos are not able to run and display on STM32F769i-DISCO using v2.6.0.
Below is the terminal log
You may also refer to https://community.st.com/s/question/0D53W00000O1KHJSA3/run-target-on-stm32h747idisco-failed
Run Target
Generate
Done
Generate Assets
make -f simulator/gcc/Makefile assets -j8
Reading ./application.config
Done
Post Generate
touchgfx update_project --project-file=simulator/msvs/Application.vcxproj
Done
Post Generate Target
touchgfx update_project --project-file=../STM32F769I_DISCO.ioc --platform=m7
Done
Compile
make -f ../gcc/Makefile -j8
Reading TouchGFX/application.config
Linking TouchGFX/build/bin/target.elf
Producing additional output formats...
target.hex - Combined internal+external hex
intflash.elf - Internal flash, elf debug
intflash.hex - Internal flash, hex
extflash.bin - External flash, binary
Done
Flash
make -f ../gcc/Makefile flash
STM32CubeProgrammer v2.6.0
Error: External loader C:\Program cannot be loaded.
Error: External loader Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\bin\ExternalLoader\MX25L512G_STM32F769I-DISCO.stldr cannot be loaded.
Error: No debug probe detected.
make[1]: *** [_extflash_] Error 1
gcc/Makefile:295: recipe for target '_extflash_' failed
../gcc/Makefile:53: recipe for target 'flash' failed
make: *** [flash] Error 2
Failed
Failed
- Labels:
STM32CubeProgrammer
STM32F7 Series
‎2020-12-15 2:04 AM
I used cubeprogrammer 2.5 instead, as per
‎2020-12-10 12:20 AM
Hi @victagayun​ ,
There is a known issue in STM32CubeProgrammer v2.6.0 with paths containing spaces.
what's working with v2.6 :
1- open a CMD (windows command line) in STM32CubeProgrammer bin folder.
2- copy your hex in bin folder.
2- Call CLI in this way : STM32_Programmer_CLI.exe -c port=swd -d Firmware.hex -el ExternalLoader/ExternalLoader.stldr (replace ExternalLoader.stldr with the desired external loader);
You can also use the GUI for downloading your hex.
Hope it helps you.
Houda
‎2020-12-15 12:59 AM
Hi @victagayun​ ,
I hope my suggestion helps you to run your Demo.
If your question is answered, please close this topic by choosing Select as Best to. This will help other users find that answer faster.
Houda
‎2020-12-15 1:42 AM
Not being able to run out of their default installation directory doesn't seem like a satisfactory solution.
Surely the calling app should be quoting the passed path?
‎2020-12-15 2:04 AM
