CubeProgrammer Static library files
Snapark
I'm trying to use the cubeprogrammer api in my win32 application for firmware update. I'm able to do this, but there's a lot of .dll files that are required and it clutters the entire project. Is there any way you can provide a static .lib (code library instead of import library) file for linking it during compile time?
Thanks,
Rahul
0 REPLIES 0
