2025-10-23 10:49 PM
I'm experiencing an issue with the X-Cube-AI Pack (version 10.2.0) on Windows 10.
After using the X-Cube-AI Pack, the syscalls.c file is either not generated at all, or if it already existed in the project, it gets deleted during the process.
This is causing build failures since the file is required for proper compilation. I've tried this on multiple projects and observed the same behavior consistently.
Could you please investigate this issue? It would be helpful if you could confirm whether this is a known problem or if there are any workarounds in the meantime.
Thanks in advance for your support!
Best regards
2025-11-17 1:46 AM
Hello @eric_green ,
I suggest that you retest the code generation with the last version of STM32CubeMX.
How to get STM32CubeMX 6.16.0:
Under this link .
Or update your current installation of STM32CubeMX using: Help > Check for Update
I will be waiting for your feedback.
Thanks.
Mahmoud
2025-11-18 2:19 AM
Hello @eric_green ,
The first issue: Tasks,Queues,Timers,Semaphores,Mutexes are missing when reloading the ioc is fixed on the last
STM32CubeMX Version 6.16
For the second issue and as WA I suggest that after the first generation, you rename the syscalls.c file.
It is confirmed and I will let you know when it is fixed.
Thanks.
Mahmoud
2025-11-19 7:16 PM - edited 2025-11-19 7:17 PM
Thank you for your prompt follow-up and your efforts!
