STM32CubeMX.app fails to launch via Finder on macOS systems using case-sensitive APFS
CaptainKrall
The application bundle contains Contents/MacOs instead of the required Contents/MacOS. On case-sensitive file systems, this prevents LaunchServices/Finder from starting the app.
  • The binary runs correctly when launched directly from Terminal.
  • Renaming MacOs → MacOS also seems to solve the issue.
Seems to be an error in the ST packaging system.
Ghofrane GSOURI
Hello @CaptainKrall
I have performed a test using macOS Tahoe 26.0 (Intel) and was able to successfully launch the latest version of STM32CubeMX 6.16.1 via Finder.
The application bundle  contains Contents/MacOs .
Could you please provide more details about your environment:
1- Your macOS version
2- Your CPU architecture (Intel or ARM)
3- The STM32CubeMX version you are trying to launch
This information will help us better understand and reproduce the issue.
THX
Ghofrane
Hello Ghofrane,
did you try it from a system on case-sensitive file system? I won't expect the problem to arise on an Apple default installation, but as a developer, I had to re-install macOS on case-sensitive volume because of my UNIX tools.
My system:
  • macOS Tahoe 26.2
  • M4 Max (ARM CPU)
  • STM32CubeMX version 6.16.1
Cheers, Marc
Hello @CaptainKrall
Your change request has been escalated to dev team for feasibility check under internal ticket ID 225041
I will keep you posted with updates.
THX
Ghofrane
