STM32CubeIDE Linux Support
JLeng.2
I'm trying to install STM32CubeIDE on Ubuntu 16.04. The release note of CubeIDE version 1.6.1 says it's tested on Ubuntu 18.04 and 20.04. Does v1.6.1 support Ubuntu 16.04? If not, which version of the IDE should I get?
Thanks!
TSaga.1
I don't know if v1.6.1 runs on Ubuntu 16.04, but if you want to make sure, that you have a working version: I use STM32CubeIDE v1.4.2 on Ubuntu 16.04 without any problems. The IDE even gives you a prompt, that there are newer versions available, so you might be able to upgrade to v1.6.1 that way.
Thank you! This is good to know.
