stm32c0 enableIT i2c1 and usart1
Hollis_K
Hi, here I am facing the problem on I2C interrupt if USART enabled IT, my I2C IT does not work but it work correct if USART does not enable it interrupt. Any setting i missed out?
USART and I2C are independent peripherals and can have interrupts enabled at the same time. Perhaps debug your code and look for issues as to why it's not working.
Hi @TDK, I noticed that interrupt when LL_USART_EnableIT_RXNE and LL_USART_EnableIT_TXE, it will cause I2C unable trigger its interrupt although I tried send data to I2C. May I know why it happen?
But, I have solved my issues because I only require Transmit complete in my program, just wondering why enable TXE and RXNE will lead these problems.
Anyway, thanks.
Probably your code has a bug.
