RTC calibration oputput on STM32H7x with LL driver - Bug report
‎2023-10-05 4:10 AM
I tried to enable in the CubeMX section PB2 as calibration output, but it was not working.
The fix is to add a couple of lines after the RTC init:
/** Enable Calibration
LL_RTC_CAL_SetOutputFreq(RTC, LL_RTC_CALIB_OUTPUT_512HZ); //<-- will not work, registers are write protected!
/* USER CODE BEGIN RTC_Init 2 */
/* Disable the write protection for RTC registers */
LL_RTC_DisableWriteProtection(RTC);
LL_RTC_EnableOutRemap(RTC); //<- to enable output on PB2
/* Enable the write protection for RTC registers */
LL_RTC_EnableWriteProtection(RTC);
/* USER CODE END RTC_Init 2 */
STM32CubeIDE
‎2023-10-10 7:19 AM
Hello
Sorry for late answer, this issue is reproduced and it is reported internally .
Internal ticket number: 163446 (This is an internal tracking number and is not accessible or usable by customers).
Thank you
Souhaib
‎2023-10-05 6:48 AM
Hello @MD and welcome to the community.
Thank you for having reported this issue
Can you please provide more information about the MCU and CubeMX version you have used.
Thank you.
Souhaib
‎2023-10-06 2:35 AM - edited ‎2023-10-06 4:19 AM
‎2023-10-10 7:19 AM
Hello
Thank you
Souhaib
