Nucleo-L496ZG-P Issue flashing board
cbarb2747
For the first week of having the board, I was able to load different programs with no problem. Somehow, it seems that I got the board into a bad state.  Now, most of the times when I try to flash a program to the board I get the infamous:
Waiting for debugger connection...
Target is not responding, retrying...
Debugger connected
Shutting down...
Exit.
Sometimes, I can get a program to flash if I, hit the reset button a bunch, unplug and plug back in the board, clean the workspace,
rebuild the workspace, then load the program. This is very annoying and frustrating when trying to
program and then debug a program. I have also tried different chords.
Any help would be greatly appreciated. I am not sure how this happened. Everything was run super smoothly at first with the board.
10 REPLIES 10
Although this solution is intended for STM32H7, you could also test it on your NUCLEO-L496ZG-P , which uses an external SMPS.
