2021-07-26 2:52 AM
MCU GCC Linker options are
-mcpu=cortex-m3 -T"C:\Users\ssz\STM32CubeIDE\temp\edmr2\STM32F103VETX_FLASH.ld" --specs=nosys.specs -Wl,-Map="${BuildArtifactFileBaseName}.map" -Wl,--gc-sections -Wl,--verbose -static --specs=nano.specs -mfloat-abi=soft -mthumb -Wl,--start-group -lc -lm -Wl,--end-grouptoolchain is GNU Tools for STM32 (9-2020-q2-update)
regex.h is in C:\ST\STM32CubeIDE_1.5.1\STM32CubeIDE\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.9-2020-q2-update.win32_2.0.0.202105311346\tools\arm-none-eabi\include
2021-07-26 3:02 AM
2021-07-26 3:21 AM
Yes, I also had a problem with off_t and solved it as you suggest. This however does not solve undefined reference to `regcomp'.
2021-07-26 4:03 AM
@Cartu38 OpenDev do you have working code with regex.h available? Could you show your MCU GCC Linker options? If you use CubeIDE go to project Properties -> C/C++ Build -> Settings -> Tool Settings -> MCU GCC Linker.
2021-07-26 5:39 AM
Not functional neither. I guess answer is here: https://answers.launchpad.net/gcc-arm-embedded/+question/208555
I've got a look to all .a provided file as part of toolchain, none of them is promoting 'regcomp' implementation.
Maybe https://github.com/kokke/tiny-regex-c is good solution
