I try to use pmd-eclipse plug-in (static analysis tool). Plug-in is installed and I added -vm corresponding option in stm32cubeide.ini to define correct jdk version but it still not works
DWeya.1
The error message says that this plug in needs jdk 17 : jdk 17 is installed and I have added the option -vm with corresponding path to javaw.exe. Error Message is still present after CubeIDE restart.
Billy OWEN
Hi @DWeya.1​
The forum moderator had marked your post as needing a little more investigation and direct support. An online support case has been created on your behalf, please stand by for just a moment and you will hear from us.
Billy
Billy OWEN
Hi @DWeya.1​
Billy
