CubeIDE "crash" after few moments
JDosp.1
Hi All,
I started to have issue with CubeIDE. It "crash" / "close itself" after few moment after startup. Log is attached. I have tried this:
  • Uninstalled CubeIDE 1.18.1 and I have done clean install 1.19.0, without success
  • I have created new workspace
  • I have disabled checking updates in CubeIDE, but without any success
  • I have restarted computer (Win 10 Pro 22H2), temporally disabled AV software and firewall, no Windows KB update was installed before issue started (only Edge-WebView2 update 1.0.3351.48)
Thank you for any advice
Jan
JDosp.1
Issue solved. There was a pending update for the CubeMX software. It seems this somehow interfered with CubeIDE. After startup of CubeMX and finishing update, CubeIDE works properly.
Jan
4 REPLIES 4
JDosp.1
Jan
Pavel A.
The log shows update attempt. So disabling update did not work. Try to disconnect from network completely, then reinstall.
Yes, I this tried also. It seems updater from CubeMX somehow broke CubeIDE. Reinstall did not fix issue as I said.
Jan
Had similar issue. Uninstall CubeMX from system fix problem.
