Cube IDE Live Expressions flashing to 537067472 (0x20020020)
user0123
Visitor
I'm fairly new to using Cube IDE and have ran into some issues. I've been using live expressions to keep track of some data but out of no where it started flashing 537067472 (0x20020020) for all variable I was tracking. To my knowledge it's not affecting my program but when I tried to use Cube monitor the issue was also present there. The chart would jump up to 537067472  for a few cycles before going back down to the correct value. Has anyone else experienced this issue and how did you fix it? Thank you!!
For context I'm using the WB55rg nucleo board
0 REPLIES 0
