2025-08-29 1:45 AM - edited 2025-08-29 1:46 AM
VS Code report: "Unable to contact the STM32Cube registry, verify your Internet connection..."
Can I know the registry URL of the STM32Cube bundles registry and test its connection?
2025-09-24 12:50 PM
@chaaalyy
We are facing today a severe server issue that prevent the extension to download the bundles (essential ST components to run the services). We apologize for this situation and doing our upmost to solve the issue.
Bad timing I'm so sorry about. We'll update you asap.
2025-09-24 10:34 PM
@Jakob K.
2025-09-24 11:59 PM
@chaaalyy @Jakob K. The bundle registry service is now online, let us know if something continues to fail. Otherwise apologize for bad experience, the first time it happened with this server location since 2019.
2025-10-04 9:57 AM - edited 2025-10-04 9:58 AM
Hi @Julien D. Eventually it worked, seems I chose an unlucky date to try the Cube extensions :(
Now I am experiencing the 'Unhandled: on_readmemory_request not available in PyDevJsonCommandProcessor' message and VS Code's Python Debugger no longer works. The issue has been reported here and there. Can you explain what happens using the ST extensions and is using VS Code profiles the only possible solution?
2025-10-05 12:51 PM - edited 2025-10-05 12:52 PM
@Jakob K. I can’t write more about, excepting that we have an internal ticket for this specific issue. Hopefully we’ll deliver a fix in a next release if something is feasible on our side.
Until then Profiles are the way to go yes.
2025-10-07 7:21 AM
@Jakob K. The 'Unhandled: on_readmemory_request not available in PyDevJsonCommandProcessor' has been analyzed and fixed, it will be delivered with next release. Apologize for the inconvenience.
