Ethernet server with Apache2/PHP/MYSQL/PhpMyAdmin (LAMPP)
2019-05-21 3:27 AM
I'm currently working into STM32MP157C-DK2 and I have made my own image with the following append:
apache2 php phpmyadmin php-cli mysql5
But into my internet page (move from //usr/share/.. to another directory) php code didn't work and when I try to configure mysql5 I have this
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
Also I try to add php-modphp but the bitbake fail
I try too to install dev-pkgs but I get an error too
Do you have any idea ?
- Labels:
STM32MP15 Lines
2019-06-24 9:03 AM
Hi @AZAMA
Sorry for late reply.
Is this post still valid ?
Most of the module you mentioned are by default integrated to the default OpenSTLinux running on DK2 through meta-oe and meta-webserver layers.
Could then please be more specific on what you have done to generate your own image and share the logs in case of errors.
Thx
Olivier
