Custom u-boot splash screen
NPal.2
Hi all,
I have small query around u-boot.
  1. How can i update my custom boot screen for the u-boot?
  2. How can add my custom application to start post boot?
Thanks.
Jean-Marc B
Hello @NPal.2​
About your second question, I think you should look at systemd service and use its features. Define a systemd service file (I let you search information on internet) and once your systemd service file is created, just run the commands:
$ systemctl enable <myservice>
$ systemctl start <myservice>
$ systemctl status <myservice>
You can integrate the start of your application through systemd into your Yocto application recipe. Your recipe had to inherit from systemd:
inherit systemd
In your do_install function, install your files in particularly your service file:
do_install() {
[snap]
   install -d ${D}${systemd_unitdir}/system
   install -m 0644 ${S}/<path to your file>/<myservice>.service ${D}${systemd_unitdir}/system
[snap]
Then complete your recipe with these lines:
SYSTEMD_PACKAGES = "${PN}"
SYSTEMD_SERVICE_${PN} = "<myservice>.service"
SYSTEMD_AUT_ENABLE_${PN} = "enable"
(the last line is optional as «enable» is the default).
Best regards,
--JM
Jean-Marc B
Hello @NPal.2​
For your first question, I think you can update the recipe under layers/meta-st/meta-st-stm32mp/recipes-bsp/u-boot/u-boot-stm32mp-splash_2018.11.bb and add your images in the directory layers/meta-st/meta-st-stm32mp/recipes-bsp/u-boot/u-boot-stm32mp-splash,. Be careful to respect existing format and dimensions (see ST image examples).
For your next question, I am sorry but I don't have the reply and let some experts to reply to you.
Best regards,
--JM
Hi @Jean-Marc B​ : Thank you for the response. Will try the same and see if i can achieve that.
Jean-Marc B
Hello @NPal.2​
inherit systemd
do_install() {
[snap]
[snap]
Best regards,
--JM
