systemd didn't generate a "dev-ttySTM0.device" unit, and therefore stopped getty
SMich.1
i moved to new ecosystem v2.0 "dunfell" and added my layers of wifi,camera, openCV and python packages from old Yocto ecosystem.
first boot serial-getty@ttySTM0 working fine.
on second boot it died and in /var/log/messeges i got:
Unit serial-getty@ttySTM0.service is bound to inactive unit dev-ttySTM0.device. Stopping, too
I can't understand what i did wrong in Yocto layers that making this bug.
 did someone had this issue?
4 REPLIES 4
Olivier GALLIEN
Hi @SMich.1​
Did you take complete and consistent ecosystem v2.0 "dunfell" components version ?
I understand you keep openCV and python package version similar to old "thud" version, right ?
Please double check there is no compatibility problem. I would recommend to upgrade on dunfell version for all those packages.
Hope it help,
Olivier
Olivier GALLIEN
SMich.1
  1. i using all new components of dunfell
  2. i switched to new package versions of .
i did added new distro and machine. but everything else working
SMich.1
what i can check in yocto layers that may help me?
SMich.1
I found that in file /extlinux/extlinux.conf ihave:
APPEND root=PARTUUID=491f6117-415d-4f53-88c9-6e0de54deac6 rootwait rw console=ttySTM0,115200
but still the console=ttySTM0,115200 not passed to Getty service ...
so I just did:
vi /boot/extlinux/extlinux.conf
added space after 115200
resaved the file and now the ttySTM0 passed to Getty service.
First of all the problem was not with the v2.0 "dunfell" . it something with my yocto layers config . somebody can help?
