2020-11-27 1:35 AM
I am trying to use a STM32MP157C in combination with a lan9303 chip in mdio mode.
when booting I get an error that says:
LAN9303_MDIO: probe of stmmac-0:01 failed with error -22
This prevents the driver from being loaded succesfully.
I added the lan9303 according to the device tree bindings:
ðernet0 {
status = "okay";
pinctrl-0 = <ðernet0_rmii_pins_a>;
pinctrl-1 = <ðernet0_rmii_pins_sleep_a>;
pinctrl-names = "default", "sleep";
phy-handle = <&switch>;
phy-mode = "rmii";
max-speed = <1000>;
mdio0 {
#address-cells = <1>;
#size-cells = <0>;
switch: switch-phy@1 {
compatible = "smsc,lan9303-mdio";
reg = <0>;
ports {
#size-cells = <0>;
port@1 {
reg = <0>;
label = "cpu";
ethernet = <ðernet0>;
phy-mode = "rmii";
fixed-link {
full-duplex;
port@2 { /* external port 1 */
reg = <1>;
label = "lan1";
port@3 { /* external port 2 */
reg = <2>;
label = "lan2";
};Does anybody know, what might cause this error?
Thanks.
2021-01-25 11:48 PM
Make sure you have checked this article from ST wiki: https://wiki.st.com/stm32mpu/wiki/Ethernet_overview.
Your port@1 configuration seems strange to me. You should get 3 external ports provided by your lan9303 chip and only mdio port to configure
your phy.
