How to get 'gatttool' command to work
2021-03-09 9:54 AM
I'm working with the stm32mp157f-dk2 and with OpenSTLinux and I'm trying to create a GATT service for provisioning the wifi credentials.
The problem is, according to https://wiki.st.com/stm32mpu/wiki/How_to_scan_BLE_devices I should be able to run the gatttool command. Unfurntently I'm not.
I have already re-flashed the OpenSTLinux and I also have reprogrammed the kernel.
I'm running the OpenSTLinux 5-4 20-11-12.
What should I do? I have also tried the apt-get install command..
Thanks,
Fernando Fontes
OpenSTLinux
2021-03-31 7:45 AM
Hi @FFont.1
The gatttool is available after installing the package bluez5-noinst-tools :
root@stm32mp1:~# apt-get install bluez5-noinst-tools
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following NEW packages will be installed:
bluez5-noinst-tools
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
root@stm32mp1:~# which gatttool
/usr/bin/gatttool
root@stm32mp1:~# gatttool -h
Usage:
gatttool [OPTION?]
Help Options:
-h, --help Show help options
--help-all Show all help options
--help-gatt Show all GATT commands
--help-params Show all Primary Services/Characteristics arguments
--help-char-read-write Show all Characteristics Value/Descriptor Read/Write arguments
Application Options:
-i, --adapter=hciX Specify local adapter interface
-b, --device=MAC Specify remote Bluetooth address
-t, --addr-type=[public | random] Set LE address type. Default: public
-m, --mtu=MTU Specify the MTU size
-p, --psm=PSM Specify the PSM for GATT/ATT over BR/EDR
-l, --sec-level=[low | medium | high] Set security level. Default: low
-I, --interactive Use interactive mode
Best regards
JM
2021-03-15 10:06 AM
Hi @FFont.1 ,
I understand Gattool is provided by gattlib module.
Is it the one you tried to app-get ?
Olivier
2021-03-31 7:45 AM
Hi @FFont.1
bluez5-noinst-tools
/usr/bin/gatttool
Usage:
gatttool [OPTION?]
Help Options:
Best regards
JM
