2023-01-18 1:22 PM
I would like to set the low-power timer as wake up source to wake up the Linux from sleep mode with some periodic time, let's see every 5 minutes. All I have found is pwm and counter examples here: https://wiki.st.com/stm32mpu/wiki/LPTIM_device_tree_configuration
2023-01-18 11:24 PM
Hello
I suppose you need to:
example provided here for UART4:
https://wiki.st.com/stm32mpu/wiki/Power_overview#Example_of_wakeup_source_activation
echo enabled > /sys/devices/platform/soc/40010000.serial/tty/ttySTM0/power/wakeup
echo enabled > /sys/devices/platform/soc/40010000.serial/power/wakeup
(LPTIM @ is 40009000)
make sure the clock for LPTIM are activated during the sleep mode
(only some possible hint, I am not familiar with DT myself, hope it helps)
JM
2023-01-18 11:24 PM
Hello
JM
