on 2021-10-26 01:29 PM
This was very helpful! Where can we find the source code for this application?
Here is the link to the source code: https://github.com/azure-rtos/samples/releases/download/v6.1_rel/Azure_RTOS_6.1_B-U585I-IOT02A_IAR_Samples_Beta_2021_10_01.zip
It is not exactly the same as the code used in this tutorial as the quick connect example is intended as an introduction/demonstration.
Thanks for you reply!
I already went through this and made it work - a little caveat though, I had to build it using IAR IDE and was hoping if it's supposed to be added to the STM32CubeIDE projects sometime soon?
Alternatively, I can convert it to an STM32CubeIDE project I assume, but would be great to have everything at one place.
I have read your excellent post. This is a great job. I enjoyed reading your post for the first time.
I want to say thanks for this post. Thank you
Any chance I can get the source code of this project on B-U585I-IOT02A Discovery Kit?
there isn't source code from Github. thanks!
Is there any user guide: Using STM32Cube IDE to connect B-U585I-IOT02A Discovery Kit to Azure IoT?
