Wifi on B-U585I-IOT2A using SPI
I'm working on the Wifi on the board B-U585I-IOT2A.
I'd like to connect 2 modules, including the microcontroller, to the same wifi so that they can communicate with each other.
I've made some research about Wifi MXCHIP EMW3080 and example HTTP_IOT_HTTPSERVER but i still not succeed to connect any network by taking parts of the code
Has anyone ever encountered this problematic before ?
could the lwip library be useful?
Thanks you for your help.
