TWu.6
What is the maximum value of HS_STARTUP_TIME for BlueNRG-1?
  • July 20, 2023
  • 1 reply
  • 726 views
Hi friend,
I want to extend the HS_STARTUP_TIME for BlueNRG-1. What is the maximum value of HS_STARTUP_TIME for BlueNRG-1? I saw the datasheet AN4494 it says that "XTAL_startup = XTAL_startup_measured*1.2*1.1*1.3 = 1.716*XTAL_startup_measured".  So 1953uS--> HS_STARTUP_TIME = 1074. But I use BlueNRG-1 IFR tool calculate 1953uS--> HS_STARTUP_TIME = 800 (0x320). Which is correct? Can anyone guide me? Thank you in advance.
Best wishes
Ted Wu
1 reply
TWu.6
TWu.6Author
Hi Friend,
Who can tell me what is maximum value of HS_STARTUP_TIME for BlueNRG-1? What is the size of IFR of HS_STARTUP_TIME? How much will HS_STARTUP_TIME become if it is set to exceed 1953uS?
Tedd Wu
